Creating saved views
Command
Path
View bar
Save View
View
To save the current drawing area view:
Do one of the following:
Select the command.
Click Saved Views from the View bar, and then select New Saved View.
From the Organization dialog box, click the Saved Views tab, and then click New.
If a Design Suite product is installed, from the Navigation palette, click the Saved Views tab, and then select New from the Utility menu.
The Save View dialog box opens.
Specify the view options, the layer and class visibility settings, and define the view transition parameters when moving to the view being saved.
Parameter
Description
View Name
Specify the view name
Save view orientation
Saves the general view parameters of the active layer, including the projection, 3D orientation, and page origin settings. If Vectorworks Design Suite is installed, the plan rotation and the clip cube position are also saved.
Save zoom and pan
Saves the zoom and pan settings of the active layer
Save page location
Saves the design layer page location with the view; if deselected, the current page location setting is used when the view is displayed. The page location of sheet layers cannot be saved.
Save render mode and options
Saves the render mode and options with the view; if deselected, the current render mode and options are used when the view is displayed
Saving the render settings with the view is an effective method of saving and restoring custom rendering options.
Save DMX
(Spotlight required)
When Showcase is active, saves a single frame and current DMX of the live view or DMX playback
Save data visualization
Saves the currently applied data visualization view; see Viewing the drawing by data or by attributes
Save object visibility
(Design Suite product required)
Saves object visibilities with the view; see Object visibility changes using the Visibility tool
Save layer visibility
Specifies the layer visibility options to save; if deselected, the current layer visibility settings are used when the view is displayed
Layer Options
Select the design layer display options
Active Layer
Select the active layer; if a sheet layer is selected, the Layers button is disabled
Layers
Opens the Layer Visibilities dialog box; specify the design layer visibilities for the saved view (see Visibility columns)
Save class visibility
Specifies the class visibility options to save; if deselected, the current class visibility settings are used when the view is displayed
Class Options
Select the class display options
Active Class
Select the active class from the list of classes
Classes
Opens the Class Visibilities dialog box; specify the class visibilities for the saved view (see Visibility columns)
View Transition
To define the transition to this saved view, select whether to:
Use the Animate view transitions Vectorworks preferences (see Vectorworks preferences: Interactive pane)
Set a custom transition for this saved view
Have no transition
Duration (s)
For a custom view transition, enter the duration in seconds for the transition to this view
Motion
For a custom view transition, select the transition's motion.
Decelerate starts fast and gradually slows
Accelerate starts slow and gradually increases speed
Smooth accelerates the view transition at the start and decelerates to the end
Linear maintains a constant speed throughout
The view is added to the saved view list, available in multiple locations; see Viewing saved views.
Editing saved views
Redefining saved views
Setting global visibility with class and design layer options
